Groupbuy Pulley Set + Schwungscheibe UR
Dann will ich das 3er Set :D....Wann schickst du meine restlichen Teile los? Mit dem gleichen Container Matce?
Will2k
30. Januar 2007
Wels
#26
Hier ein paar Zitate zum Thema :)
Don't expect any miracles in terms of performance though. However, you can expect a much more responsive throttle and notable quicker acceleration in gears 1-3 (more in 1st, less in 3rd). I did this mod with the fidanza flywheel, so i cant tell exactly how much of an impact its actually made, but i was reasonably satisfied with the end result
I would go with Unorthodox racing pulleys. They are OEM diameter, just lighter. I put them on my celica, minus the crank pulley. They do a little for you, but its mostly just helped acceleration and throttle response. It made my motor's overall tone change very slightly, and you can hear it when you get on the gas once they are installed.
I brought a set of UR water and alternator pulley in early Feb when I came back to the States to visit some old friends.
This thing works great and I don't have any problem with it.
I don't suggest you to put it on unless you have lightened flywheel like me.
I found the engine more willing to rev high.... Happy reving.
Since it is a fact that lightened flywheel requires little more skills to start the car from dead. The engine makes nasty sounds when I pop the clutch too fast. With the pulleys on, the engine is more tolerant for mistake. Right now, even I pop my clutch too fast, the engine won't choke.
Ich übersetz euch das nicht, english mustn't be a foreign language ;)
ThinkAbout
G.
EDV-Techniker
#27
sodale ... für die s sind jetzt aba scho 3 pulleys, oder?
@willi setzt mi bitte auch auf die liste :) (flywheel + pulleys)
Will2k
30. Januar 2007
Wels
#29
wenn noch jemand aufspring für das set bedeutet das 16% Ersparnis,... das sind ¤ 140.- weniger für jeden Käufer ;)
Will2k
30. Januar 2007
Wels
#31
ich lasse den GB jetzt noch bis ende jänner laufen, danach leite ich die bestellungen weiter,.... hoffe das passt so für alle beteiligten !?
Leut wir bräuchten noch einen für ne Schwungscheibe!!!!! So günstig kommt ihr so schnell an die nicht dran!!!!
Will2k
30. Januar 2007
Wels
#35
"opfern"? :) is glaub ich die falsche bezeichnung,...
ich würds als günstige gelegenheit bezeichnen sich eins zu holen :)
ThinkAbout
G.
EDV-Techniker
#36
"up" nochmal :)
leute, hier bekommt ihr leistung für wenig geld ;) kommt schon, hat keiner daran interesse? :(
Danny
19. Juni 2006
Steinheim an der Murr
ausgelernter Bürokauffmann und nu Selbstständig
#37
Ist die Bestellung jetz schon raus???
Was würde mich das ganze zeug jetz ma ungefähr mit Einbau kosten???
müsste bissl kalkulieren bin knapp bei kasse :D
Will2k
30. Januar 2007
Wels
#38
Bestellung ist noch nicht raus,
Set kommt auf ¤ 730
Einbau: ca. ¤ 300 (Antriebswelle muss runter, Arbeitsaufwand = so viel wie bei Kupplungsaustausch)
Liebe Grüße, Willy
