StopTech Stainless Steel Brakelines
sander_jappower
5. April 2009
StopTech stainless steel brake lines improve pedal feel and reduce the amount of time between applied pedal pressure and actual deceleration by preventing expansion, which stock rubber flex lines allow. This provides a quicker pedal response, and allows the driver to maintain consistent brake pressure and precision brake modulation.
StopTech brake lines consist of a Teflon® inner line that is covered with a layer of stainless steel woven braid. The Teflon tube is very resistant to expansion under pressure and will not degrade from exposure to brake fluid. The stainless steel braid provides support for the Teflon and the weave is extremely durable against incidental impact and abrasion. StopTech brake lines feature a Clear Abrasion Resistant Cover for maximum protection against chaffing
All StopTech Stainless Steel Brake Lines are DOT compliant and 100% tested to a pressure of 4500 psi.
Front - TOYOTA Celica 140/190 2001-2006 = € 59,50
Rear - TOYOTA Celica 140/190 2001-2006 = € 49,50
Front - TOYOTA MR2 (SW20) 1991-2000 = € 69,50
Rear - TOYOTA MR2 (MR-S Spyder) 2000-2006 = € 59,50
Front - TOYOTA MR2 (MR-S Spyder) 2000-2006 = € 59,50
Rear - TOYOTA Supra JZA80 (All) 1993-1998 = € 79,50
For more information PM or e-mail to sander@jappower.nl
