Special March offer: ACT Clutches
sander_jappower
5. April 2009
Hi Celica-drivers,
Especially for this community I am having a special March offer on ACT CLUTCHES.
After spending long hours and thousands of dollars building that high powered engine, you need a quality clutch that can properly transfer that power into motion. Count on ACT clutches for quality, performance and affordability.
ACT recognizes that every driver and engine set-up is unique, so a variety of complete clutch kits and components are offered to match virtually any situation. ACT’s complete clutch kits include a pressure plate, disc, release bearing, and (in most cases) a pilot bearing and alignment tool.
The kit guide on http://www2.advancedclutch.com/media/pdf/clutchkits_engagement.pdf will help you select the ACT kit that best fits your needs. The following pages include ACT clutch kits and components listed by application. Torque capacities are provided for every clutch combination. When a specific flywheel is required for an ACT Clutch, it will be designated in the chart for your convenience.
Consider carefully which clutch is right for your car. First you need a clutch that will hold all the power, but not too excessive. For street use, you also need a long lasting clutch that has a positive feel, smooth engagement and quiet operation. For racing, you need a tough clutch that will enable quick shifts and hard slips all the way to the finish line.
For more information: http://www2.advancedclutch.com/products/clutchkits.aspx?prod_id=6050#6050
For more information or ordering please contact me by PM or send an e-mail to sander@jappower.nl
