- 5. April 2009
- Zustimmungen
- 0
LARGE JULY GROUPBUY
This groupbuy is posted on several forums. The wideband might be intresting for you Celica drivers. The boostcontroller and turbo timer probably not.
AEM UEGO Digital Wideband Air / Fuel Gauge
A wideband UEGO sensor controller accurately monitors Air/Fuel ratios (AFR) during the tuning process to prevent a lean fuel mixture, which could lead to engine damage. AEM has combined its single-channel wideband UEGO controller and gauge display into one unit, uniting unsurpassed AFR accuracy and control with an easy-to-read interface. AEM’s Gauge-Type Wideband UEGO Controller features a digital LED display and sweeping LED “needle” that changes colors as AFR changes from rich to lean. The unit’s 52mm (2-1/16”) gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere.
- Ideal AFR monitoring tool for EFI and carbureted applications, and engine dynamometers
- Does not oscillate AFR reading like narrow band sensors
- No laptop required for monitoring!
- Bosch sensor included
- Accurate to 0.1 AFR
- Reads in AFR or Lambda via a switch in back of gauge housing
- 24 Color-coded LED display lights provide immediate reference to engine’s air/fuel ratio (AFR) or Lambda ratio
- Integrated three-digit display reveals AFR or Lambda in real time
- User-programmable 0-5v analog output included for use with data loggers and virtually any engine management system
- Serial data stream included for output of AFR (RS 232)
¤279
AEM TRU-BOOST Gauge-Type Controller
AEM’s TRU-BOOST Gauge-Type Controller is an electronic boost controller that combines the simplicity of a manual boost controller with the added ease of adjusting boost levels through a gauge interface. There is no external interface required for set up, and it is fully functional right out of the box. There are no gimmicks or special software programs included. If you want more boost press the button on the right of the gauge face, and if you want less boost press the button on the left of the gauge face. It’s that simple, and IT WORKS!
AEM’s TRU-BOOST Gauge-Type Controller includes everything you need, including an on-board 29 psig pressure sensor, built-in Overboost protection with two timed shutdown levels, a scramble boost setting and a low-side output for a warning light. AEM offers a 75 psia boost sensor for high boost applications (sold separately).
AEM’s boost control solenoid (included) is the only one specifically manufactured for automotive boost applications, which means it won’t corrode and stick from exposure to rich fuel mixtures, it is pressure tested to 100 psi and includes -4 AN fittings to eliminate any chance of leaks.
- No external interface required for programming!
- Complete system includes harness, boost hose, on-board 29 psig pressure sensor (external 75 psia optional), boost solenoid, gauge display and all necessary fittings
- Quick connect technology eases the installation process
- Two user selectable boost settings with peak boost memory
- Scramble boost setting allows user to momentarily change boost levels
- User selectable Overboost alarm includes two timed shutdown levels at 10% and 20% Overboost
- User configurable gauge includes 24 scalable LEDs, and interchangeable bezel, pin guide and faceplate to customize look of display
- One (1) low-side output included for warning lights
¤309
GREDDY TURBO TIMER - HET NIEUWSTE MODEL!!!
New launched by Greddy is their detachable style turbo timer! This allows you to hide away the main unit and flush mount the display almost anywhere!
Standard features include:
2 Pre-Set Times
2 Auto-Mode Times
Voltage Meter
Speedo
Clock
¤119
Groupbuy is alsvolgt:
1-5 ¤279
5 or more ¤259
1-5 ¤309
5 or more ¤289
Greddy Turbo Timer
1-5 ¤119
5 or more ¤109
This groupbuy is posted on several forums, and they all count!
1. Other forum
2. Other forum
3...........
4...........
5...........
1. Other forum
2...........
3...........
4...........
5...........
Greddy Turbo Timer
1...........
2...........
3...........
4...........
5...........
THIS GROUPBUY IS VALID UNTILL 31ST OF JULY
For more information you can send a PM or e-mail to sander@jappower.nl
¤279
¤309
2 Pre-Set Times
2 Auto-Mode Times
Voltage Meter
Speedo
Clock
¤119
1-5 ¤279
5 or more ¤259
1-5 ¤309
5 or more ¤289
Greddy Turbo Timer
1-5 ¤119
5 or more ¤109
1. Other forum
2. Other forum
3...........
4...........
5...........
1. Other forum
2...........
3...........
4...........
5...........
Greddy Turbo Timer
1...........
2...........
3...........
4...........
5...........
