Cosworth New Forged Pistons for Toyota & Lotus 2ZZ-GE
jlacelica
25. August 2009
Available in 3 compression ratios 10.0:1 12.0:1 14.0:1
Cosworth 10:1 Piston = 278.2g (18% lighter) Part No. 20029439
Cosworth 12:1 Piston = 278.2g (18% lighter) Part No. 20029440
Cosworth 14:1 Piston = 293.8g (13% lighter) Part No. 20029441
Price 1115 eur
Cosworth's premium piston set includes 4 pistons, piston ring set and 4 piston pins with retainers. Fits all Lotus/Toyota 2ZZ-GE engines. 10.0:1 compression suits supercharged, turbocharged and nitrous applications.
Cosworth's forged piston set for the 2ZZ engine is engineered and built to be the best available.
Meticulous design and machining allowed Cosworth to build the lightest piston available for the 2ZZ at only 278g for the 10.0:1 model- that is an incredible 60g lighter than the stock pistons! Cosworth even supplies ultra light wristpins weighing just 71g (18g lighter than stock.)
Cosworth's proprietary low friction skirt coating along with the included gas nitrided piston rings make these pistons 100% compatible with all stock bores, iron sleeves and Nikasil bore coatings.
Designed in CAD based on a digitized combustion chamber to optimize all clearances, combustion chamber shape and quench areas
With 50 years of world class engine design and manufacturing experience, Cosworth's extensive knowledge of complete engine dynamics provides a distinct advantage in piston design resulting in the finest piston available.
John kommt aus NL und kann daher kein deutsch.
du musst ja weder was bei ihm kaufen noch seine Beiträge lesen. Gibt hier genug die schon bei ihm was gekauft haben und kein Problem hatten...:rolleyes:
ein wenig, aber wir haben Google Übersetzen so fragen mich, was Sie wollen ;)
http://translate.google.nl/#de|nl|
