Air System Package
*** Extra €200 Discounts if purchase with WORK/RAYS/WEDS Wheels ***
Accu Air Management Kit + BC Racing Coil Over + UAS Bags - €3699
Kit Included
- Single Compressor Kit
- E-Level Management provide auto leveling
- BC Racing Coil Over
- UAS Universal Air Bags
- Power Cables
Quote:
Order this kit if you don't have any existing coil over. UAS bags will replace the spring on the BC coil over. This kit will included everything you need for air suspension setup.
Accu Air Management Kit + UAS Bags - €2899
Kit Included
- Power Cables
Quote:
Order this kit if you already have BC racing, Megan Racing or similar type coil over. UAS bags will replace the existing spring on the coil over.
Accu Air Management Kit + KSport Struts with Bags - €4099
Kit Included
- Ksport Struts with Bags Build In
- Power Cables
Quote:
Ksport struts with built in bags allow for extreme low drop. This kit included everything.
Air Runner Full Air System with Accur Air E-Level Management - €5499
Kit Included
- Air Runner System Included Full Manual Switch, KYB Shocks Built with Air Bags
- Accur Air E Level Management (auto leveling)
- Power Cables
Quote:
This kit included a full manual switch system in addition to the Accu air E-level auto height adjustment. Air Runner system are built in Japan.
Optional Add On:
- Accu Air Exo Mount Kit provide one simple solution to mount all the accu air modules on the air tank. - €249 Extra
- Additional Compressor (400c) For Faster Up movement and also back up in case first compressor fail. - €199 Extra
- Accu Air Wifi Module, Allow Iphone, Ipad control of the air system - €349 Extra
Coil Over Setup
BC Racing Coil Over - BR Series - €999
KW Coil Over - PM For Pricing
Ksport K Control Pro Coil Over - €999
