Update: Verkaufe mein mini ITX Board mit CPU, RAM, und Festplatte. Wie schon der Titel sagt verkaufe ich meinen fast kompletten Car PC. Board: Mini ITX (170mm X 170mm) Intel® Pentium® 4 processor, 1.7GHz~3.06GHz Intel® 82845GV built-in VGA, AGP 4X, support CRT Optional Chrontel CH7017 LVDS supports LCD panel or TV Out Realtek 8100BL 10/100Mb LAN controller One DDR socket supports up to 1GB Memory Digital I/O (4 in/4 out), one PCI slot, AC97, four USB ports, four COM ports CPU Socket Socket 478 CPU Intel® Pentium® 4 processor, 1.7GHz~3.06GHz+ Hyper-Threading supported Chipset Intel® 845GV chipset Processor Side Bus Frequency 533MHz/400MHz L2 Cache 128K/256K/512K, CPU integrated BIOS Award BIOS, ACPI supported System Memory One DDR slots Support up to 1GB PC200/266/333 DDR SDRAM VGA Intel® 845GV chipset integrated, AGP 4X LAN Realtek 8100BL LAN Controller (10/100Mb) Audio ICH4 integrated audio with AC97 Codec ALC 650 6-Channel LPC I/O Winbond 83627HF supports IrDA x 1, Parallel x 1, COM1, COM2 (RS232), FDC up to 2.88MB (3 Mode support), hardware monitoring Secondary I/O Fintek F81216D supports COM3, COM4 (RS232) IDE Interface Built in ICH4 IDE1: 40-pin box header (Ultra DMA 33/66/100) IDE2: 44-pin header FDD Interface Supports up to two floppy disk drives: 3.5" and/or 5.25" drives; 3 Mode support Parallel Port One parallel port supports SPP/EPP/ECP Serial Ports RS-232 x4 Watchdog Timer Generates system reset; 256 levels Hardware Monitoring Built in Winbond W83627HF; monitors system/CPU temperature and voltage status USB USB 2.0 compliant Supports 4 USB ports IrDA Pin header Keyboard and Mouse Connector PS/2 type keyboard and mouse connectors Digital I/O 4 in / 4 out Expansion Slots 1 PCI, support 2 bus master Power Connector ATX 12V power connector Form Factor Mini ITX motherboard Dimensions 170mm x 170mm Power Consumption Power Consumption Intel® Pentium® 4 processor 2.4GHz (256KB) with 256MB DDR memory +5V: 3.29A; +12V: 4.83A Intel® Pentium® 4 processor 3.06GHz (512KB) with 512MB DDR memory +5V: 3.17A; +12V: 7.14A Bord ist in einen sehr gute Zusatand und lief die ganze Zeit Stabil ohne Abstürze, selbt bei starken Temeraturschwankungen, im Winter wie im Sommer. Es gibt nur ein kleine Problem, mir fehlt die ATX Blende was aber kein Problem ist und die Funktion nicht beeinträchtigt. Instalations und Treiber CD sowie das Hanndbuch ist mit dabei. Dazu gibt es noch ein P4 CPU/2,66Ghz, Arbeitsspeicher 512MB, 40Gb 2,5" Festplatte mit passenden IDE Kabel fürs Board. Es wird nur noch ein mini ITX Netzteil benötigt: Zu empfelen währe das M2-ATX 6-24V DC/DC (160 Watt) was es hier gibt http://www.cartft.com/catalog/il/574 Verkaufspreis setze ich Komplett bei 400€ an. Auf Wunsch kann ich gegen einen Aufpreis das System noch vorinstalieren mit passender Software (Navigation mit Europakarte, Diagnose Software, Car-PC Desktop Oberfläche, DVD Player und einige anderre Software nach Absprache. Solten noch Fragen sein einfach melden. Und noch zu Schluß. Warum ich das ganze Verkaufe. Naja ich habe was neues gefunden mit SATA Anschluß und noch einige anderren Sachen. Da mein Car PC Projekt am erweitern ist und ich mehr Leistung und größerre Festplatte brauche kaufe ich mir lieber was neues befor ich noch Geld in das anderre System stecke. Mfg. Denny
Naja das Angebot bleibt erst einmal stehen bis sich jemand zu 100% meldet und solange kommt auch nix neues. Muß zur Zeit auch etwas aufs Geld schauen, da ich mir Heute eine neue Sub Entstufe für 600€ gekauft habe. Aber ist erst einmal für dich reserviert wenn sich nix anderres ergibt. Mfg. Denny
Was braucht man dann da noch alles um es an nen Touch screen anzuschliessen und was muss ich noch machen damit ich per Bluetooth daten von meinem Rechner auf das ding schicken möchte das ungefähr 20 meter von mir entfernt steht? mfg ach ja haste mal nen bild von dem ding? Und die rechnerleistung reicht doch normalerweise für die programme aus oder nicht? weil du hast doch mal so ne diagnosesoftware gezeigt, funktioniert die auch flüssig mit dem rechner?
So das Board sieht so aus: CPU, Festplatte und Arbeitsspeicher ist ja klar. Dann brauchst du noch ein CPU Lüfter, kostet nicht die Welt, Das Netzteil wie im ersten Tread schon geschrieben (79€) das wars auch schon wenn noch erwünscht ein CD oder DVD Laufwerk aber das kann man später nachrüsten, ewenduell noch ein Gehäuse ist auch nicht teuer oder man bastelt sich was. Für Bluetooth ein Bluetooth USB Adapter kostet auch nicht viel (reichweite von 100m bis 150m. Diagnosesoftware läuft flüssig und ohne Probleme dafür braucht man nicht viel Leistung. Und anderre Programme die man so fürs Auto braucht auch kein Problem. Mfg. Denny
So update Komplett für 400€ (nur Hardware) Software nach Absprache. Bekomme nächste Woche mein neues Board und wenn alles gut läuft ohne Probleme muß das alte Board weg, da es sonst rum liegt. Bin aber ab Morgen für eine Woche Offline aber es können sich schon mal Interresenten melden. Und bei Fragen auch einfach schreiben. Mfg. Denny
